December 1, 2021 at 6:37 pm
eliocpereira
SubscriberI would like to know how to properly comment in a journal to be read by Ansys Fluent. I know that I may use the semicolon
;to tell Ansys that the text in front of it in the same line is not a command. However, when I read a journal with such structure the line is printed to the console, which is not the usual result that is obtained in cases of other Programming languages such as C and Python. I would like to read the journal without the comments being printed to the console. Is it possible to do that?Also, is any counterpart of the command "cout" (in C++), "printf" (in C) or "print" (in Python) that can be used in Ansys Fluent? Or should I use the semicolon instead?
December 2, 2021 at 12:51 pmRob
Forum ModeratorThe semi colon means the line is seen as a comment and ignored. It doesn't mean the line won't be printed to the TUI. Journals are used to trigger commands, so it's not usually a problem.
Viewing 1 reply thread- The topic ‘How to comment in a journal to be read by Ansys Fluent’ is closed to new replies.
6680
1313
