January 5, 2021 at 12:20 pm
xqzhang
SubscriberHello, everyone. I need to change the UDF from udf1 to udf2 after some iterations. When I use GUI, I can do this by unload the old UDF and compile the new UDF. However, when I try to do this by TUI, I can not delete the udf1 from the source file, which means the udf1 will be compiled again and the udf2 coudn't be compiled as shown in the following figure. I want to konw how to change the UDF by TUI. Thanks.
January 5, 2021 at 12:25 pmxqzhang
SubscriberSometimes I cannot add a new UDF, as shown in the picture, I type yes, but the result is the same as if I typed no. Other times, After I type yes, I can enter a new UDF file name, but the new UDF will be compiled with the old UDF library name, although the UDF library name has been changed.nJanuary 5, 2021 at 1:35 pmRob
Forum ModeratorWhy not compile all of it inside one .c file and use an IF (something) statement to switch from one setting to the next? nJanuary 5, 2021 at 1:46 pmxqzhang
SubscriberThanks, Rob. In fact, I've spent a lot of time trying to implement all the functionality in one UDF, but unfortunately the idea has never materialized.When a UDF is used, an error is reported directly in the first step of the calculation and floating point overflow occurs.Therefore, I thought that changing the UDF might be a temporary solution, which was in fact possible, but It was not clear to me why the functionality that the GUI was able to implement would go wrong in the TUI.nJanuary 5, 2021 at 4:18 pmRob
Forum ModeratorWith Windows you may want to unload the existing library then compile the new .c file (or load the new library). There are some odd write protect features that aren't present on LINUX that can cause issues. nJanuary 5, 2021 at 4:20 pmxqzhang
SubscriberThanks, Rob. I will try it on Linux.nViewing 5 reply threads- The topic ‘How to change the UDF by TUI?’ is closed to new replies.
4878
1587
1386
1242
