how to change the automatic value of the contour legend ANSYS AQWA HD
    • Nurhalim Dwi Putra
      Hello everyone,
      I want to display a visualization using the pressure and motion wave contour display in Ansys AQWA HD, using several different photo results, but the max-min value in the legend remains the same in each photo result. How do I set it so that this value can be customized and not automatic? Where do I find it in the menu? Because currently the default menu is locked.
      Thanks
    • Mike Pettit
      I'm afraid there is no way to modify the min/max values in recent versions of Aqwa Workbench. I will try to get this fixed for the next release.
      Mike
  • The topic ‘how to change the automatic value of the contour legend ANSYS AQWA HD’ is closed to new replies.
