how to change material for elements between load steps and continue the simulation?
    • Jirong
      Hi ALL,
      I'm trying to use MPCHG to change material for some elements between load steps if the elements' EPELX is negative, and then go back to the solution processor and continue for a next load step.
      I found this APDL script from SimuTech website, but don't know how to use it correctly. Any suggestions?
      *GET,current_loadstep,ACTIVE,,SET,LSTP ! current load step number
      *IF,current_loadstep,EQ,0,then ! before first load step SOLVE
      ! Location of macros in user_files
      FINISH
      /PSEARCH,_wb_userfiles_dir(1) ! provides location of “user_files”
      /SOLU
      *GET,my,ACTIVE,,JOBNAM ! jobname, <= 8 characters
      /DELETE,my,rdb ! if exists, req’d for single frame restart
      RESCONTROL,DEFINE,NONE ! no files for multiframe restart
      *ENDIF
      *IF,current_loadstep,GT,0,then ! after a load step SOLVE
      FINISH
      /POST1
      SET,LAST ! just in case not loaded
      *GET,num_elem,elem,,COUNT ! how many elements
      *GET,num_elem_max,elem,,NUM,MAX ! highest element number
      ! example examination of results
      ETABLE,my_epeq,NL,EPELX ! Example
      *DEL,my_epeq,,NOPR ! delete array without warning
      *DIM,my_epeq,ARRAY,num_elem_max ! array to hold strain
      *VGET,my_epeq(1),ELEM,1,ETAB,my_epeq ! element table column to array
      FINISH
      /SOLU
      ANTYPE,,REST ! single frame restart
      ! Example: make changes according to my_epeq array contents
      current_elem=0
      *DO,ii,1,num_elem ! step through elements
      current_elem=ELNEXT(current_elem) ! next element
      ! create changes for this element per my_epeq(current_elem) value
      *ENDDO
      ALLSEL
      *ENDIF
      ! At this point, WB follows with the next SOLVE using the above settings…
      Thanks,
      JL
    • ErKo
      HI
      This is a not standard use of mechanical - we can only give some hints of what to do here.
      Add an if statement at that line (see *if in the apdl manual) to check the my_eplx(current_elem) is negative.
      If it is, then use the mpchg command (see apdl help manual), to change its property.
      All the best
      Erik
    • Jirong
      Thanks for your reply!
      I try to use *if statement to achieve your suggestion:
      *IF,my_epeq(current_elem),LT,0,then
      CMSEL,s,my_epeq(current_elem)
      MPCHG, maxMaterialNumber,my_epeq(current_elem)
      *ENDIF
      But I got error said "Component MY_EPEQ is not defined" after *if statement was executed.Here is the error message:
      *IFmy_epeq(current_elem)( = -0.300000E-01 )LT
      0( =0.00000)THEN
      SELECTCOMPONENT MY_EPEQ
      *** ERROR ***CP =2.422TIME= 19:05:18
      Component MY_EPEQ is not defined.
      How to select the elements that satisfy the *if statement ? Do I need to create another array for CMSEL?
      Thanks Jirong
    • Felix Aschmann
      Hi Jirong CMSEL selects a component, but you haven't defined a component.
      If you wanted to select the element then you need to issue the 'esel' command.
      However for changing the material assigned to an element you don't have to select the element. It's sufficient to issue the MPCHG command for the element(s) you want to change.
      Regards!
  • The topic ‘how to change material for elements between load steps and continue the simulation?’ is closed to new replies.
