How to calculate Wall Temperature using AnsysFluent
    • Sam001
              How to calculate Wall Temperature when you have more than one wall surface,
                                       Fin area/Total area
                                      and Total heat Transfer area/volume between plate  using AnsysFluent?
      Thanks,
      Sam
    • DrAmine
      You already have access to it at walls. What is still missing?
    • Sam001
      Amine,
                Am I to use the net for the overall Wall Temp?
      Thanks,
      Sam
      Depends which wall you want to the data for. You need to work out what you want data for.
    • Sam001
      rwoolhou,
                    ok, what of fin area/Total area?
    • DrAmine
      More details: what do you want to Do?
    • Sam001
      Amine,
                 finding Stanton number?
      Sam
    • DrAmine
      So you need averaged values along the wall (say like area-weighted) and the whole area of the wall. Stanton is: St = Nu / (Re * Pr) so you need to use some "global" charateristics for your flow. Fluent provides Surface Stanton Number as post-processing variable based on the reference values.
    • Sam001
      Amine,
                Please, can you break down the term "global" characteristics?
      Sam
    • DrAmine
      Reference Temperature, Reference Length for example to define Nu and Re.
    • pssjn
      is it possible to calculate the wall temperature of 'zero thickness wall'? what is the best way to calculate natural air ventilation rate of a room in fluent?
      Best regards,
      Farhan
    • DrAmine
      Yes you can. Please mark this as is Solved and open new discussion for your new question.
Viewing 11 reply threads
  • The topic ‘How to calculate Wall Temperature using AnsysFluent’ is closed to new replies.
