TAGGED: fluent-eddy-viscosity, k-omega-model, k-omega-sst
September 15, 2023 at 2:03 pm
ztjia
Subscriberwhen I use the SAS-SSTÂ model, I do not understand the epsilon(turbulence/turbulent dissipation rate epsilon). Does the "epsilon" represent the turbulent dissipation rate in SAS-SST model? I know that SAS-SST model can tranfer to the LES-like mode in the unsteady flow, so is the turbulent dissipation rate in SAS-SST model calculated by " effective viscosity*strain rate*strain rate"? hoe you can help me, thank you, waiting for your reply. Also, how to calculate the dissipation rate in the SBES model (k-omega SST)?
September 20, 2023 at 6:16 pm
Essence
Ansys EmployeeYes, epsilon is the turbulent dissipation rate. Please refer to the Ansys guide link:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/flu_th/x1-1810005.20.2.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/flu_th/flu_th_sec_turb_scales_SBES.html?q=sbes
September 21, 2023 at 6:42 am
ztjia
Subscribersorry,the link I can not open
September 21, 2023 at 6:43 am
ztjia
Subscribersorry, I can not open the link?is there any problem?
September 21, 2023 at 8:13 am
Forum ModeratorClick on Help in Fluent & paste the above into the browser that opens. Documentation is password protected but the solvers have a token/cookie/biscuit to bypass that step.Â
September 22, 2023 at 5:26 am
ztjia
Subscriberthanks for your reply. there still are some questions. for example, when I use SBES model based on the k-omega SST, how to calculate the subgrid viscosity? does the effective viscosity in fluent(Turbulence variable) include the subgrid viscosity? and under the SBES model, does S(strain rate tensor) represent the instantaneous velocity?
- The topic ‘How to calculate the turbulence dissipation under the SAS-SST model in fluent?’ is closed to new replies.
5189
1848
1387
1249
