August 26, 2023 at 5:33 pm
xiaofei.xiao15
Subscriber -
August 28, 2023 at 11:18 pm
Guilin Sun
Ansys EmployeeFor linear polarization, you can do two seperate simulations with x and y polarized source (z propagation), calculate polarized transmission by integrating the individual Poynting vector; or you use a 45 deg polarized light. for example,
PoyntingV=Ex*conj(Hy)-Ey*conj(Hx) is the totalÂ
PoyntingV_X=Ex*coj(Hy)Â X-polarized
PoyntingV_Y=-Ey*conj(Hx);Â Y polarized
then you integrate them: integrate - Script commandÂ
Do not forget 0.5 and use the real part:https://optics.ansys.com/hc/en-us/articles/360034405354-transmission-Script-commandhttps://optics.ansys.com/hc/en-us/articles/360034405354-transmission-Script-commandÂ
and normalize with sourcepower:https://optics.ansys.com/hc/en-us/search?utf8=%E2%9C%93&query=sourcepower
For circular polarization, you have to decompose the monitor data from Ex,Ey, Hx and Hy into EL,ER, and HL, HR, and then do the same thing.
Please note that this is based on the assumption that the near field does not have higher order diffraction. In case it has, you will need to use grating analysis (supose it is periodic, or "s param“ analysis group otherwise) to get the farfield Ep, Es, and then calculate their power. In this case you can get the power from the optical intensity: /forum/forums/topic/ansys-insight-guangxueqiangdugongludianchangqiangdupingfangdeguanxiyijidiancinengliang/
Since it is plane wave (at least in the farfield), directly use abs(E)^2 is ok. However if it is angled, you may need to correct the cosine factor.
Please find some reference papers for the decomposition.
- The topic ‘how to calculate transmission of a particular polarized tranmission’ is closed to new replies.
4107
1487
1318
1156
