How to Calculate Pressure force on a Selected surface
    • thamarai
      Hi guys,
      Iam doing a pressure lost analysis in a valve, In which I want to calculate pressure force acting in the piston region as shown in fig. I used Pressure inlet and pressure outlet boundary conditions. I tried the following methods but didn't worked
      1.Post Processor---> Functional calculator
      >Force. I got near to zero newton force.
      2. Post Processor ---> Drawn a plan and through functional calculator, calculated avg pressure in the plan which didn't gave logical value ( I gave 6 bar at inlet pressure and 4.5 bar at the outlet  while using this method I got pressure force more than 15 bar which is impossible )
      3. Report ---> Area-weighted Average/Integral/Vertext Average.. All gave zero as the result.
      Can you Kindly guide me to find the solution?
    • Keyur Kanade
      I assume you are using Fluent solver.
      Can you please check if your solution is converged or not in Fluent?
      Can you please check it in Fluent using Results --> Surface Integrals?
      https://www.youtube.com/watch?v=SsORGWCg1ss
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
    • thamarai
      Dear Keyur,
      Thanks for your help. It is working..
      Thamaraikannan
  • The topic ‘How to Calculate Pressure force on a Selected surface’ is closed to new replies.
