HOW TO ASSIGN ELEMENTS TO NAMED sELECTION IN APDL?
    • Katala
      Hello all,
      im trying to assign two element groups in one named selection. You can see the code below. The elements from Material 4 and 5 i put in named selection but after that if i try to put addiotionally the elements from Material 6, it only compute with elements from Material 6. How can i assign both element groups. Can anyone please help me.
    • Wenlong
      Hi Katala,
      Can you try this:
      esel, s, mat, , 4, 5    ! select elements with mat 4 & 5
      cm, mat_4_5, elem   ! Create a name selection with name mat_4_5
      esel, a, mat, , 6,6    ! Add element with mat 6
      cm, mat_4_5_6, elem   ! Create a name selection with name mat_4_5_6
      Wenlong
  • The topic ‘HOW TO ASSIGN ELEMENTS TO NAMED sELECTION IN APDL?’ is closed to new replies.
