March 18, 2021 at 9:21 am
Lukas8778
SubscriberHey there,nI need to design and simulate a PMSM for a master thesis. I'm new to the software and wondering how it is possible to assign a constant sinusoidal current to my 3 phase machine via Maxwell2D.nI created an IPM Synchrounous machine via RMxprt, when I create a Solution setup I only have the option to define the rated voltage as follows:
With this setup I get way to high Stator Currents- these are automatically calculated.n
For my motor I calculated a constant current of i_q=750A. Is it possible to assign these value somehow ?nI would be really glad if someone can help.nnThank you and kind regardsnnnLukas n
March 18, 2021 at 2:06 pm
NKC
Forum ModeratornFirst, create a full maxwell model from the RMXprt model as discussed in your other post.nThen under the project manager window for the maxwell design change the excitations for the phases to current and give a required sinusoidal equation for each phase.n For additional help please refer to the Maxwell help document.n
nRegards,nNavyan
- The topic ‘How to assign a constant sinusoidal current to a PMSM?’ is closed to new replies.
- Hfss 3D pcb via capped and filled with epoxy
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
1494
1386
1209
