April 4, 2020 at 10:43 am
momidor
SubscriberDears,Â
I'm gonna to provide simplified stress simulation which supposed to be show a influence of postwelded residual stress to the surroundings.
Question:
1. how to apply a shear and normal stress to the "hoop" respresents the filled weld ?
2. If the answer is name selection > node selection question is how to apply to each node from "hoop" in perpendicular, longitudinal and tangentially to the middle surface of the filled weld ?
For example I applied a pressure acting perpendicular to end plane ( or along to the its longitudina crookedl axis ) of the "steel ribbon" represents an helical seam weld and got a an stress which embrace only partial of this plane.
The point is that the curve suppose to be taut as a rope around a pipe.
Thanks in advanced
JurekÂ
April 6, 2020 at 3:41 pm
Sai Deogekar
Ansys EmployeeHello Jurek,
I am not completely familiar with all the terminologies with regards to welding. But to answer you question 2: If you know the components of the forces to be applied in terms of the global coordinate system, then under Details --> Definition --> Define by: "Components". Then you can define the force or pressure in terms of the x,y,z components.
Hope this helps,
Sai
April 6, 2020 at 6:14 pm
momidor
SubscriberThanks Sai. I've done it already.Â
- The topic ‘How to apply shear and normal stress’ is closed to new replies.
6455
