September 16, 2021 at 5:15 pm
yz12b
SubscriberI have searched online but found few solutions. We know the v-profile at the BC, in order to implement zero-vorticity, we'd like to add du/dy to the BC based on the v-profile. It seems the only way to do it is to use the UDF. But the UDF manual is very hard to follow.
I think it is something like DEFINE_UDS_FLUX, and C_U_G(c,t)[1] is for du/dy. But I have no clues to complete the UDF. Hope someone can help. Thanks in advance.
September 17, 2021 at 10:43 amRob
Forum ModeratorHave a look at the DEFINE_PROFILE example, and also have a look at Expressions in the recent releases.
September 17, 2021 at 1:40 pmyz12b
SubscriberHI Bob, I checked but couldn't find an example for this. I also check the UDF for shear stress, which is similar, but no clues yet. What do you mean by 'Expressions'? Thanks.
September 17, 2021 at 1:45 pmRob
Forum ModeratorIf you just want to vary velocity with position then there is an example in the manual: it's THE example for the macro I suggested.
Viewing 3 reply threads- The topic ‘How to apply du/dy at BC using UDF in FLUENT?’ is closed to new replies.
5849
