How to apply BFE loads from *.csv file?
    • npbauskar
      Hi, I am new to APDL scripting. I want to read *.csv file containing time and heat generation load. And these 1D data i would like to use to apply BFE load. nHow can I do that? nThank you in advancen
    • 1shan
      ,nIf you are open to using workbench, you could do this by loading the *.csv file into the external model component and then linking it to the setup of transient thermal. You could have a look at
      and /forum/discussion/8529/transferring-explicit-dynamic-results-to-mapdl. Any reason why you are using APDL? The learning curve for workbench is much easier and faster.nRegards,nIshan.n
  • The topic ‘How to apply BFE loads from *.csv file?’ is closed to new replies.
