August 28, 2024 at 7:15 am
itoito405231
SubscriberI am conducting an analysis using a constant magnetic field in Maxwell. The only method I know of for applying a constant magnetic field is to place coils or permanent magnets. However, I do not want to use coils or magnets, which may attenuate depending on the distance, so I am searching for a method to apply a constant magnetic field inside a box. I have heard of such a method before. Thank you in advance for your help.
August 28, 2024 at 9:41 am
ErKo
Ansys EmployeeHi
One way is to use a mixture of zerotangentialhfield , symmetry and zero zerotangentialhfield boundary conditions.
See here how it can be done:
https://www.youtube.com/watch?v=tjqxn3a29JU
Hope it helps.ÂErik
August 29, 2024 at 12:04 am
itoito405231
SubscriberThank you for reply. I'll try it.
1885
1404
1303
