October 13, 2021 at 1:42 pm
AbdulZahir
SubscriberI have simulated my case and now i need to analyze the liquid hold up in the packing area. How can i do so? Can someone please guide me?
October 14, 2021 at 1:22 pmKarthik Remella
AdministratorHello I'm not sure if I understand your question completely. Do you wish to estimate the volume of liquid in the domain?
Karthik
October 14, 2021 at 1:45 pmAbdulZahir
SubscriberYes I need to estimate the liquid volume per volume of packing (domain).
October 15, 2021 at 10:14 amAbdulZahir
October 19, 2021 at 1:52 pmKarthik Remella
AdministratorHello I'm assuming that this is a multiphase simulation. You could estimate the volume of the region where the volume fraction is either 0 or 1 (depending on which phase you select). You should be able to create an iso-clip based on a set criterion and then estimate the volume using the Volume Integrals solution. You can then divide by this obtained value with the total volume of the domain.
Karthik
October 19, 2021 at 2:59 pmRob
Forum ModeratorDepending on the model used you can also report the phase volume in the domain.
October 28, 2021 at 7:34 pmAbdulZahir
SubscriberSo you mean i need to calculate the volume of secondary phase (m3) (water in my case) in interior of the geometry and then divide it by the total volume (m3) of the domain ?
October 29, 2021 at 11:25 amRob
Forum ModeratorYes, just use the volume integral for each volume you need to report on. Note, porous media doesn't occupy a real volume so use some caution.
Viewing 7 reply threads- The topic ‘How to analyze the liquid holdup in post processing?’ is closed to new replies.
5934
1307
