October 25, 2021 at 9:21 am
raju.chowdhury
SubscriberHi, I am simulating droplet-solid interaction using VOF multiphase model. How can I add the wall surface roughness 0.06 micro meter?
October 25, 2021 at 9:45 amRob
Forum ModeratorThere are wall roughness parameters for turbulent flow, but that's not useful here. At 0.06microns there isn't much you can do, if you want to add the roughness to the CAD it'll be lost in the tolerances. What are you trying to find from the model?
October 25, 2021 at 11:12 amraju.chowdhury
SubscriberI want to investigate the effect of roughness on droplet spreading.
October 25, 2021 at 1:23 pmRob
Forum ModeratorSo you'd actually need to resolve the surface distortions? Otherwise it's a factor to add to a source term into momentum equations or a fudge on surface tension at the free surface.
Viewing 3 reply threads- The topic ‘How to add wall surface roughness ?’ is closed to new replies.
5754
