how to add mixture with different proportion of materials in ansys fluent
    • gopikrishna
      Im trying to do  a simulation based on basic oxygen furnace. So i need to add a mixture of material that comprises of fluid and solid for the simulation. but these mixtures are in terms of weight percentage. how i can add mixtures in weight percentage in fluent?
    • Kalyan Goparaju
      Please see the link below on how to create a mixture. (section 16.1.4 of Ansys Fluent 2020 R1 User Guide)
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/flu_ug/flu_ug_sec_species_mixture_custom.html
      Once the mixture is created, at the inlet boundary, you can define the mass fraction of each of the species.
      Thanks,
      Kalyan
    • gopikrishna
      thank you Sir!
    • gopikrishna
      Sir, if in a simulation Im filling a room with a gas through an inlet, does the room interior contains air as default before letting gas inside in ansys fluent?? or i should assign interior fluid as air?
    • Kalyan Goparaju
      You need to assign the material for the cell zone. In the 'Physics' tab, under 'Zones', select 'Cell Zones' and ensure that the Material Name is set to whatever material you want inside this cell zone.
      Can you mark both answers as solved so that it will be useful for others.
      Thanks,
      Kalyan
Viewing 4 reply threads
  • The topic ‘how to add mixture with different proportion of materials in ansys fluent’ is closed to new replies.
