May 15, 2021 at 5:37 am
juan_arb
SubscriberHey there!
I am new to simulation with ANSYS WorkBench. Currently, I am trying to simulate the effect of standard earth gravity on a concrete cylindrical post (like a light post). For that, I want to add two boundary conditions each at the same distance (a) from the edge, as shown in the image:
May 15, 2021 at 11:49 ampeteroznewman
SubscriberHey John Delete the surfaces and curves.
Select Split on the Design tab and split the face of the cylinder with the plane.
That will create an edge on that face that will be available in mechanical for applying boundary conditions.
May 15, 2021 at 5:22 pmjuan_arb
SubscriberThanks a lot . Do you know any way I can parameterize the distance where the cut (split) is made?
May 15, 2021 at 5:36 pmpeteroznewman
SubscriberUse the Move tool and click the split edge. Click a single axis, use a pop-up menu to measure the distance from the end and click the parameter button.
Viewing 3 reply threads- The topic ‘How to add boundary conditions to a cylinder in ansys mechanical?’ is closed to new replies.
6625
1311
