February 15, 2023 at 1:56 amSooyeon KimSubscriber
Hi. I am a beginner of Ansys FDTD, and interested in simulating optical properties of organic materials, especially bio one, for example, structures made of protein and DNA molecules. However, in the default material data base, there is no database which can be used to simulate such organic materials.
I have two questions.Â
1) Is there any other similar materials in the database to use as an alternative to these materials above?
2) Is it possible to manually add database of new materials? If so, what kind of measurements do I need to do?
Thank you very much in advance and I look forward to hearing advices from you who may have had similar questions!
February 27, 2023 at 11:04 pmGuilin SunAnsys Employee
I have to write something otherwise the system always sends reminder message.
- The topic ‘How to add biomaterial in the material database?–Duplicated’ is closed to new replies.
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- INTERCONNECT – No results unless rerun simulation until it gives any
- Import material .txt file with script
- Help for qINTERCONNECT
- Trapezoidal ring
- Issues with getting result from interconnent analysis script
- Topology Optimization Error
- Edge Coupler EME Example Issue
- How to measure transmission coefficients on a given plane .
1241
543
523
225
209
