how to add a preload of spring in Ansys workbench ls-dyna?
    • pengchengyin
      Hi all,
      Recently, I am using workbench ls-dyna to simulation the drop test of a rack server. But I so confused about how to add a preload of spring in workbench ls-dyna. When I try to add the preload of spring at the setting of spring, the same as the image shows at below. it doesn't work.  I want to ask, does anybody know how to add preload of spring in workbench ls-dyna?
      Thank you.
    • Sandeep Medikonda
      It can be done by using Insert>Bolt Pretension object either in a dynamic relation phase or a regular transient phase.
      See the Help on this
      How to access the ANSYS Online Help
    • pengchengyin
      Hi Sand,
      Thank you for replying me. I also have a question. should I need to delete the spring setting and use a cylinder to instead of spring by using bolt pretension?
      Thank you
    • pengchengyin
      and if I delete spring, the beam connection cannot instead of spring which has damping. But if I don't delete spring, the beam connection cannot add at the same place as spring which has kinematic incompatibility. Is that right?
    • Sandeep Medikonda
      When you are using bolt pretension, you wouldn't need to model the spring and if beam connections are available I don't see why these can't be used. Yes, but definitely not both.
      The velocities are damped but only in the dynamic relaxation phase? See this video.
      https://www.youtube.com/watch?v=ATMq_fi35Uk
    • pengchengyin
      sorry, I can't open that link. But I thought spring can affect the model damping when model drop on the gorund, which beam connection can not do. is that right? Sorry I am a new guy for workbench ls-dyna. I really appreciate you replying.
    • pengchengyin
      Or I can use beam connections and put the longitudinal damping of spring in Global Damping?
    • Sandeep Medikonda
      Why do you need it to be damped? Is a cushion between the 2 parts physical behavior?
Viewing 7 reply threads
  • The topic ‘how to add a preload of spring in Ansys workbench ls-dyna?’ is closed to new replies.
