January 26, 2023 at 12:43 pm
supratim.basak
SubscriberHow to add a new object library so that I can use it from model>>set up>> script? For e.g. here linear-waveguide-taper I want to add the taper object in the object library so that I can use it recursively during scripting?
January 26, 2023 at 5:26 pm
Guilin Sun
Ansys Employeeunfortunately you cannot add any group to the library. If you want to resue the structure, you can make a template with this group. then you load it and rename it for any new design.
Of course, you can use script to create such structure group.
- The topic ‘How to add a new object in the object library?’ is closed to new replies.
Ansys Innovation Space
1414
1256
1118
1015
