Process Integration and Design Optimization
How to access “OSL_DESIGN_DIR” Environmental variable?
    • RPraveen.Kumar
      I need to access the "OSL_DESIGN_DIR" environmental variable from the environment tab inside the batch node through batch script itself
    • ashish.khemka
      Please see if the following link helps: Ansys Discovery
      Ashish Khemka
    • Markus
      Hi RPraveen.Kumar,
      you can access it in the batch node as any other environemtal variable, you find an example here: Sensitivity Analysis of a Coupled Function
      Best regards,
      Markus
