Electronics
Electronics
how should i write the equation for a square wave with 50% duty cycle as coil input in maxwell?
    • iamhsafi
      hello! i am simulating a high power transformer in maxwell and i have to give a square wave with 50% duty cycle as an input to the coil terminals. I would really appreciate it if you could write it in the exact words as i am supposed to write it in maxwell. The frequency is 20khz.
    • Navya Chode
      Hi @iamhsafi you can use a pwl function to define the square voltage.
      You can look at the following forum discussion for how to define a pwl function. Change units appropriatly
      /forum/discussion/comment/116644#Comment_116644
      Please refer to Maxwell help document for more detail on defining pwl functions.
      Regards Navya
    • Kyrylo Kalashnikov
      Hello! Thanks for the help. However, it looks like the link that you are referring is not working anymore?
    • GLUO
      Method 1 insert a dataset and use pwl(datasetname, time)
      Method 2 use sgn(sin(2*pi*time*Freq))
      Method 3 use external circuit and pulse source
      GL
    • GLUO
      Correction Method 2 use 0.5*(sgn(sin(2*pi*time*Freq))+1)
      GL
Viewing 4 reply threads
  • The topic ‘how should i write the equation for a square wave with 50% duty cycle as coil input in maxwell?’ is closed to new replies.
