June 15, 2018 at 3:48 am
user deleted
SubscriberHow make a plot in Ansys Workbench?
June 15, 2018 at 4:31 am
peteroznewman
SubscriberIt depends, what quantity do you want to plot?
How do you want the plot to look like?
Most plots are contours on the surface of geometry.
You can also plot along a line or a plane.
You can make an XY plot which is called a Chart. -
June 15, 2018 at 6:59 pm
user deleted
SubscriberI am calculate stress at disk gas turbine. I need make chart for stress from radius.
June 16, 2018 at 2:52 am
peteroznewman
SubscriberThen you want to create a Path under the Geometry branch, then you can plot stress along that path. Here is one reference.
More information in this discussion.
- The topic ‘How make a plot in Ansys Workbench?’ is closed to new replies.
