October 18, 2024 at 5:43 am
bcchul1
SubscriberHello,Â
I thought that only the Br value of the permanent magnet affected the motor performance in the simulation.
As shown in the figure, in order to change the Hc value, Recoil Permeability  was arbitrarily changed from the existing 1.05 to 1, and the result of examining the no-load EMF was different.
What mechanism does it operate by?
November 19, 2024 at 3:21 pm
Tamami Yamanaka
Ansys EmployeeHello,
The performance of a motor in simulation is influenced by several factors, including the magnetic properties of the permanent magnet used. While the residual flux density (Br) is indeed a critical parameter as it indicates the available flux output from the magnet, the coercivity (Hc) also play significant roles. The relationships between the four properties of a permanent magnet are explained in the following online help:
Getting Started with Maxwell: A 2D Magnetostatic Solenoid Problem
 - Setting Up the Solenoid Model > Assign Materials to Objects > Assign Neo35 to the Core > Select Independent Material PropertiesAnsys Maxwell 2024 R2 - Select Independent Material Properties
