March 6, 2020 at 1:26 pmBogdan MiroschnitschenkoSubscriber
Hi all
I have simulated 3 different 3D projects in transient simulation, so all reports are separated in the different project files.
I want to unite this reports, i.e. create only one graphic with 3 different traces for torque, each trace must be exported from a different file.
Is it possible without exporting data tables in Excel for example? What is the optimal way to do it? -
March 6, 2020 at 1:28 pm
March 19, 2020 at 12:41 pmCBAnsys Employee
You can copy curves from one graph to another graph by selecting the curve in the Results Panel and Cntrl C - copy and then select new graph in Projects Folder and Cntrl V-Paste, In the Properties Panel you can also rename the curve.
- The topic ‘How is possible to unite reports from different projects?’ is closed to new replies.
Ansys Innovation Space
- HFSS Incident Plane Wave excitement mode
- Ansys Maxwell 3D – eddy current
- How to calculate eddy and hysteresis losses of the core?
- Simulation of capacitor combining eddy currents with displacement currents
- dq graph non-conformity
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Parametrizing coil “terminals” with coil geometry
- Maxwell circuit – PWM
- On-chip inductor design
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
791
599
591
366
