3D Design
3D Design
how does tolerance value affects share topology?
    • Rahul Kumbhar
      Bbp_participant
      What is the significance of tolerance value in Share tool?
    • Charudatta Bandgar
      Hello Rahul,
      Tolerance in Share Topology defines how close faces or bodies must be to be treated as connected.
      • Low tolerance → only perfectly touching or very close bodies are shared
      • High tolerance → even bodies with small gaps are forced to share
      • If the gap is larger than tolerance, they won’t share
      So, increasing tolerance helps close small gaps, but too high can create unwanted connections.
