May 4, 2026 at 12:28 pm
Rahul Kumbhar
Bbp_participantWhat is the significance of tolerance value in Share tool?
May 12, 2026 at 1:17 pm
Charudatta Bandgar
SubscriberHello Rahul,
Tolerance in Share Topology defines how close faces or bodies must be to be treated as connected.
- Low tolerance → only perfectly touching or very close bodies are shared
- High tolerance → even bodies with small gaps are forced to share
- If the gap is larger than tolerance, they won’t share
So, increasing tolerance helps close small gaps, but too high can create unwanted connections.
