May 19, 2022 at 2:08 pm
ixg90
SubscriberI'm running an HFSS simulation that is taking longer than expected. I'd like to know how to tell HFSS to use all available processor cores and RAM.
The PC I'm using is running windows 10 with 40 processor cores, and 64GB of RAM. The windows resource monitor shows that only about half of the cores, and half of the RAM are in use during a simulation.
How do I tell HFSS to use all available processors and RAM?
May 25, 2022 at 11:42 amAncS
You can use HPC settings where you can specify the maximum number of cores and maximum RAM usability for simulation. For more information, you can go through the 'High-Performance Computing' section of the HFSS help document.
Hope this helps.
Regards
Anchal
May 26, 2022 at 3:46 pmixg90
SubscriberThank you. I've figured out how to specify the total number of cores used under Simulation -> Analysis Configuration where I've specified 40 cores, and 95% RAM limit on my local machine. I've changed "Num variations to distribute" to 11, as I'm running an optimetrics variation that has 11 steps total.
Is it possible to use multiple cores to compute different frequencies within a given simulation? It seems that I'm distributing the 11 step parameter sweep to different cores, but I'm not sure that the various frequencies within a given sweep is being distributed.
I wasn't able to find this information in the help document.
Viewing 2 reply threads- The topic ‘How do I specify how much RAM & and how many processor cores HFSS uses for a simulation?’ is closed to new replies.
Innovation SpaceTrending discussions- Three-Phase Voltage Imbalances in dual stator electric generator
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
- Two way coupling for Maxwell and thermal problem
Top Contributors-
4612
1515
1386
1209
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
