TAGGED: ansys-meshing, mesh, mesh-generation, meshing
October 28, 2020 at 11:34 pm
Flatter97xD
SubscriberHey everyone, I tried severel methods using edge sizing and face meshing, but the mesh won't fit. Could someone please help me? I don't get the issue...
October 29, 2020 at 2:56 pmGovindan Nagappan
Ansys EmployeeHi @Flatter97xDWhat do you mean by mesh wont fit? nIf you are using a newer version(2019R2 or newer), you can use Axisymmetric sweep for a body of revolution to create hex/prism meshesn
If you need a connected mesh, then you can use shared topology in geometry editor(DM or Spaceclaim). If you use shared topology, axisymmetric sweep will not work. n
October 30, 2020 at 9:25 amFlatter97xD
Subscriberthank you for your answer. This was really helpful and defenitely a step forward. nI'm doing a CZM Delamination on these two bodies. Sweep Method makes a stable mesh and shared topology connects the two meshs of the two bodies.nBut I can't choose the other Geometry for Delamnination using shared topology, it's not possible to select source and target, only the lower body...nHow can I connect the mesh and still select both faces on the contact?nOctober 30, 2020 at 9:31 amFlatter97xD
SubscriberI have to use O-Grid divisions when both bodies are selected, so nevermind, silly question... Thank you for your help!nViewing 3 reply threads- The topic ‘How do I mesh this tube/body properly?’ is closed to new replies.
6550
1311
