September 10, 2020 at 8:31 am
CFDGer
SubscriberHello,ni have the following problem: In ICEM I created a geometry in [mm] (ICEM->Settings->Model/Units->Millitmeters).nThen, when I look at my solution in Fluent Post the length of my geometry has the same value (130) but with the unit [m].How do I import the length units from ICEM to FLUENT correctly?nThanksn -
September 10, 2020 at 1:24 pm
Forum ModeratorDon't, in Fluent you'll see a scale button, read the mesh into Fluent and then scale it. I never scale anything in CAD/meshing and always alter dimensions in Fluent as needed (mm to m, mm to inches etc). n -
September 10, 2020 at 1:48 pm
CFDGer
SubscriberThats a smart idea, thank you Rob!n
- The topic ‘How do I import mm dimension from ICEM to FLUENT’ is closed to new replies.
1306
