March 6, 2017 at 6:49 pm
mingyao.ding
Ansys EmployeeI would like to get the shape/geometry of the result of a structural simulation I ran.
October 22, 2017 at 4:11 pm
peteroznewman
SubscriberThere are two approaches to get the deformed geometry out of a Static Structural solution into a CAD program: a two step process and a fifteen step process. Thanks to SimuTech group for teaching me this method.
FOR VIEWING OUTSIDE FACES ONLY
In Mechanical: Insert a total displacement for a selected body into the solution, then right click on it and export an stl file. Â
In CAD:  import the stl file. Some CAD systems don't handle imported stl files very well. New versions are getting better at that. See the next approach.
TO CREATE A SOLID BODY (more useful in CAD programs)
Here are the steps to export a Parasolid file:
In Mechanical:
- Create a Named Selection named "top" that contains the part you want to export.
- Analysis Settings set to Save APDL db
 - Drop a Mechanical APDL component onto the Static Structural SolutionÂ
- Right click on Analysis row of Mechanical APDL system on project page and select "Add Input File"Â
- Select attached input file upgeom.inp (this is setup to select a single part in your model).
- Drop an FE Modeler component onto the Mechanical APDL Analysis
- Update the Static structural solution, Mechanical APDL Analysis, and FE modeler.Â
If the Static structural solution was done before step 1 above, clear generated data first.
Open FE Modeler
8. Right click on "Geometry Synthesis" and select "Insert>>Initial Geometry"
9. Right click on "Initial Geometry" and select "convert to parasolid"
10. Drop a DesignModeler (Geometry) Component onto FE modeler Model cell
11. Update FE modeler and DM
Start DM (double click on Geometry field)
- Add a Body Operation, "Type" set to Sew, setting the "Create Solids?" to Yes
If the result is not a single solid, change "Tolerance" to User Defined.
13. In DM open Tools>>Options then go to:
DesignModeler>>Geometry>>Export Options>>Parasolid Export Version and select 24.0 for NX8
14. Export Parasolid file.Â
15. In CAD system import Parasolid file.
October 22, 2017 at 4:40 pm
peteroznewman
SubscriberThis site won't allow a file with an inp extension to be attached, so below is the contents of upgeom.inp which is attached as upgeom.txt
resume
/prep7
cmsel,s,top
esln,r
upgeom,1.0,1,last,file,rst
cdwrite,db
finish
October 31, 2017 at 11:35 am
peteroznewman
SubscriberDoes AIM have a method to get the deformed geometry back to SpaceClaim?
May 22, 2018 at 9:42 am
CakeOrDeath
SubscriberHi,
Great walkthrough! However, I seem to experience a problem when converting to a parasolid. Even though my initial geometry turns out OK, all faces, vertices, etc are detected correctly, when I convert to parasolid it doesn't detect any of the geometry correctly. I'm just trying the process out with a deformed beam so I wouldn't have thought it was too complicated to handle.
Any advice?
May 22, 2018 at 9:58 am
peteroznewman
SubscriberPlease attach your workbench archive .wpbz file and let's take a look. Also say what version of ANSYS you are using.
You would think ANSYS would build-in a useful output in a simple way, such as right mouse click > Export Deformed Geometry.
May 22, 2018 at 10:19 am
CakeOrDeath
SubscriberHi,
Thanks very much! Hopefully I have created the .wpbz file correctly, but if there are any issues then please let me know.
I'm using ANSYS version 17.1.
 Indeed! Clearly there is a need for people to use the deformed geometries in CAD software or for further analysis in other software packages, so you think it would an easier process.
May 23, 2018 at 2:52 pm
May 24, 2018 at 10:47 am
January 8, 2019 at 2:03 am
earvinlloyd
SubscriberHi,
Now that FE-modeler is phased out (in 19.1 and newer), what is the substituting procedure (besides exporting to .stl)?
January 8, 2019 at 10:19 am
Forum ModeratorIt's been relabelled as "External Model", so try that.Â
April 11, 2019 at 9:17 am
lordofthethings
SubscriberBoth External Model and Mechanical Model are not attaching with Mechanical APDL.
May 31, 2019 at 1:43 pm
NRafael
SubscriberHello,
I've been trying the procedure to obtain the solid model. But I am not understanding the step 5. Where I am supposed to get that input file?
June 9, 2019 at 12:35 pm
peteroznewman
SubscriberThis post has the text for the input file. Just rename it with a .inp file extension.
October 11, 2019 at 8:04 am
lincs2k9
SubscriberAs "FE modeller" is not available in Ansys latest version, this thread's procedure is not applicable for latest version ansys workbench. "External Model and Mechanical Model" are not working according to this procedure. Can you provide instruction using latest version? Is it possible?Â
October 21, 2019 at 4:53 am
mehdimechanic
SubscriberCan this single part in step 5 be an assembled part? some parts together? then how should the input be modified?Â
November 5, 2019 at 11:39 am
lordofthethings
SubscriberFor newer versions of Ansys that do not have a "Finite Element Modeler"
1. Run the simulation to get deformed geometry :
2. Connect the solution part of the static structural to a new instance of "Mechanical Model", update the tolerance if necessary, and check the following options in the properties of the Mechanical Model. Update both the systems.
3. Finally, bring a new instance of the "Geometry" system and connect the model to it.Â
4. Open the Geometry module in DM (Not Spaceclaim), generate it, and then File --> Export --> (STEP format). Wait until the conversion is over. Now you have the solid model ready!
November 13, 2019 at 11:44 am
Forum ModeratorHave you also linked Engineering Data?Â
Edit: don't need that, and it works fine here.Â
November 14, 2019 at 3:05 pm
lordofthethings
SubscriberInstead of dragging the mechanical model on top of the static structural, drag and drop it first as a stand-alone module BESIDE static structural (dont link it yet) Once you are done, take the solution cell from the static structural and join it with the mechanical model's Model. This should then work.
November 27, 2019 at 1:11 am
rajansanand
SubscriberBut...how to provide a fixed amount of imperfection (my model has to be given a fixed amount of imperfection by multiplying a value to the deflected shape i got in eigen value buckling analysis) -
November 27, 2019 at 11:07 am
peteroznewman
Subscriberrajansanand, this discussion is about how to convert a deformed mesh into geometry.
You are asking a different question, how to deform a mesh to use as the imperfection for a buckling analysis.
Please open a New Discussion for this question, or do a search on the site to look for an answer. -
March 25, 2020 at 2:01 am
nabilkhalid56
SubscriberHello guys,
I am trying the same method but the geometry I get in the Mechanical model isnt as deformed as it is in the solution of Static Structural. My properties settings in the workbench for the Mechanical model instance is similar to what is described in "lordofthethings posted this 05 November 2019". Can someone please help? I have also attached the image.
March 25, 2020 at 11:18 am
March 26, 2020 at 6:37 am
nabilkhalid56
SubscriberYes, the scaling of the results was the issue. Thank you so much for your fast response.
January 26, 2021 at 8:50 pm
Snow1Runner
SubscriberHi everyone, nFor the process outlined by where does one can modify the tolerance. I've got a very small deflection in a plate and when I complete all of the steps, I can't appreciate any deformation. nI can see the deformation in DM before exporting the STEP file so I am pretty sure it's not the same case as the one above of the scaling of the solution. nRegards! n -
January 28, 2021 at 6:01 am
February 24, 2021 at 9:21 pm
March 13, 2021 at 12:31 am
sandeep.balasubramanyam
SubscriberHello!nnI'm trying to export the deformed geometry from my Static Structural analysis, to be able to use the deformed model in HFSS simulation. The model I'm using is an assembly consisting of few components. nI'm using ANSYS 2020 R2 and tried following the steps provided in this discussion. For some reason, when I try to open the deformed geometry, it opens in Space Claim instead of Design Modeler. This is even after changing the settings to modify models in Design Modeler.nReally appreciate any inputs!!n
- The topic ‘How do I get deformed geometry’ is closed to new replies.
5649
1885
1404
1303
