How do I change the working directory on command line
    • shoji
      I want to change the working directory without using fluent launcher.
      Are there any commands to change working directory following this command ?
    • shoji
      I know the way to change directory using chdir command in fluent console, but I want to select working directory before fluent app start-up in command line.n
    • Amine Ben Hadj Ali
      Is this related to Ansys product? n
    • shoji
      Yes. this is about ansys fluent.nI know I can change working directory on the launcher, but now I want to change it on windows command line. nn
      What do you want do? To change the working directory while launching Fluent? All available command flags are listed when you launch with -h.n
    • shoji
      Yes.nI want to change the working directory while launching Fluent. Are there any options to change it on command line?.n
    • shoji
      I want to use fluent with matlab in ass mode. But once I start-up fluent launcher, I can't operate it from matlab. So I need to launch fluent directly from matlab and without launcher.n When I start-up fluent using below command, working directory is set to same as fluent directory( C:\Program Files\ANSYS Inc\v172\fluenttbin\win64). n
      You just ?launch Fluent in the directory you want to work in. There is no flag to tell Fluent to start in certain directoy.n
Viewing 7 reply threads
  • The topic ‘How do I change the working directory on command line’ is closed to new replies.
