February 3, 2021 at 3:26 amdhruvdeshwal17SubscriberIn 3D transient analysis (element SOLID97 of node n
February 4, 2021 at 11:27 amNavya CAnsys EmployeeHi,nPlease elaborate on what you are trying to model.nWhat do you mean by equivalent to two step loading?nProvide some screenshots for us to understand and interpret correctly what you are trying to simulate.nnRegardsnNavyan
February 7, 2021 at 2:52 amdhruvdeshwal17SubscriberThanks for your response. Section 2 and 3.1 explain about model and analysis carried out respectively.nhttps://www.researchgate.net/publication/306133315_Design_and_Damping_Analysis_of_a_New_Eddy_Current_Damper_for_Aerospace_ApplicationsYours Sincerely n
- The topic ‘How create a Permanent Magnet in which Magnetic field generated is equivalent to two step loading ?’ is closed to new replies.
Ansys Innovation Space
- HFSS Incident Plane Wave excitement mode
- Simulation of capacitor combining eddy currents with displacement currents
- How to calculate eddy and hysteresis losses of the core?
- Ansys Maxwell 3D – eddy current
- How to determine initial position in motion setup
- dq graph non-conformity
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Parametrizing coil “terminals” with coil geometry
- On-chip inductor design
- Maxwell circuit – PWM
599
591
565
366
