August 27, 2021 at 6:49 am
edoniyasbirhanu
SubscriberI am modelling and analysing simply supported concrete filled GFRP beam in ANSYS APDL, and i want to display the cracking patter of the concrete element only(EXCLUDING THE FIBER TUBE ) How could display the cracking pattern for concrete part only?
September 2, 2021 at 6:32 amRohith Patchigolla
Ansys EmployeeHello Eda Please describe a bit more on your material modeling. Which material model are you using to model concrete?
Best regards Rohith
September 6, 2021 at 6:54 amedoniyasbirhanu
SubscriberTHE MATERIAL MODEL I USED IS
CONCRETE - CPT215
REINFORCEMENT -REINF264
GFRP- SHELL181
PT TENDONS- REINF 215
September 8, 2021 at 12:51 pmRohith Patchigolla
Ansys EmployeeIt is not possible to plot the cracking pattern for Concrete. Similar result was possible with Solid65 (archived element), but this element is not recommended anymore.
Also, CPT215 is the element type. Are you using Microplane model, if yes, please have a look at the below link in help doc.
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/ans_mat/microplane.html
"4.9.2.2.7. Coupled Damage-Plasticity Microplane Damage Output
Certain microplane element quantities are available for postprocessing (/POST1, /POST26). The assigned label is MPDP.
Element outputs include the homogenized total damage (TOTA), homogenized tension damage (TENS), homogenized compression damage (COMP), and the split weight factor (RW)."
If you are using Drucker Prager material instead, you can simply plot Plastic strains to get a qualitative plots for cracking.
Best regards Rohith
Viewing 3 reply threads- The topic ‘how could display the cracking of concrete in ANSYS mechanical apdl?’ is closed to new replies.
6710
1313
