STEM
STEM
Topics cover understanding physics at a high school level.
How can you measure the distance of a storm ?
    • Akismet
    • Ashish Khemka
      You can count the seconds between seeing a lightning and then hearing the thunder. For examples if 5 seconds elap the storm would be about 1.7Km (1.05 miles) away.
    • Akismet
      ?️That's cool! How do you calculate that ?
    • prajput
      At sea level the speed of sound in air is about 340 m/s. The speed of light is much much higher than that (about 300,000 kilometers per second!). So you will first see ? the light of the lightning and then you will hear ?️ the sound that arrives at lower speed.
      Because of that you can count the seconds elapsing and then multiply by 340 to get the distance between you and the storm in meters.
      Of course this is a simple approximation, since the speed of sound can change with the air conditions.
  • The topic ‘How can you measure the distance of a storm ?’ is closed to new replies.
