How can we make two mixture materials in Fluent?
    • Hesam062
      In Eulerian transient model with species transport (non-reaction), I want to make two mixture material phases . From model >> species I selected the mixture template for phase 1 but I am confused how I can make another mixture material (for phase 2). Do I have to select a pre defined mixture form species phase property (like benzene -air ) and then modify it (delete species of pre defined mixture and add new desired species). Is there any other straight way like what I did for phase 1?nThanks for your time.nn
    • Hesam062
      The solution was simple but tricky! It toke one week to find it!!nI have selected the mixture template for all phases in species model. At this time fluent shows just ONE mixture template in material panel. So to create the seconded one I did right click on mixture template and select copy. Then new mixture template created and can be modified. nAlways I was looking for NEW command to create mixture like what we do to create/add new material. Maybe ANSYS would change it this way sometime.
    • DrAmine
      Hi Hesam, nice suggestion I will request it.n
  • The topic ‘How can we make two mixture materials in Fluent?’ is closed to new replies.
