March 18, 2024 at 2:45 pm
Daeho Jang
SubscriberIm trying to do Finite Element Analysis using Proper Orthogonal Decomposition (POD), but i cant get force matrix and dont know what result mean.ÂÂLet me first describe the process.Â1.I analyzed a cantilever beam under a sinusoidal load using the transient structural analysis in ANSYS.ÂÂ2. I exported the nodal force and nodal displacement for each node.-The mesh had 828 nodes, but excluding the 28 nodes with fixed support, I extracted the forces in the xyz direction for 800 nodes(2400 total).-The F matrix should be 2400x1. But exported txt file only contain force of 28 nodes which are fixed. Â-K matrix is 2400x2400( I used APDL code to export it)3. I stored the deformation every 0.05 seconds for 1 second into a snapshot matrix (2400x20).I subtracted the mean from the data and performed 1/N*(C*C').Â4. I proceeded with singular value decomposition on the obtained snapshot matrix and extracted 2 modes that contain 99.999% of the energy (2 basis).-I manually extracted results at 0.05-second intervals, obtaining 20 data points. Is there a method to acquire the results for all time steps at once?Â5. Using the Galerkin method, ∅^T F= ∅^T Kc∅(c is coefficient), I projected the governing equation F=KU onto the obtained basis ∅, resulting in reduced dimension of F and K matrices. ( if F matirx is 2400x1)ÂÂ6. Consequently, in the equation F = KU, all values are constants except c, and U has been reduced from 2400 variables to just 2.ÂTheres two main question.ÂÂFirst, are there any method that i can export nodal force of every nodes(800)?obtained nodal forces are useless since they are force of Fixed nodes.ÂSecond, while the original U matrix represented the deformation at each node, the reduced u_approx consists of only 2 values. What do these 2 values mean? I know those values represent the most important feature of original system but what are they?ÂIf there were any mistakes in the process, please let me know.ÂThanks -
March 22, 2024 at 11:34 am
Ashish Khemka
Forum ModeratorHi,
I have provided a response to your query here: Purpose of using POD in the finite element method, and how should i use it? (ansys.com)
Ashish Khemka
- The topic ‘How can I use Proper Orthogonal Decomposition on finite element analysis’ is closed to new replies.
1311
