Electronics
Electronics
How can I submit an Ansys Electronics Desktop file to run in a cluster that uses Slurm scheduler?
    • AveekDutta
      Hi,nCan someone help me with a batch script that would allow me to submit an Ansys electronics desktop file to run in a cluster that uses the Slurm scheduler.nAlso, I would appreciate any information on how to open an interactive session of Ansys Electronics Desktop in a node of a cluster. Right now, I can only do so on the cluster head node but I want to be able to reserve a node on the cluster and then start Ansys.n
    • ANSYS_MMadore
      I've reached out directly.nn
    • Paash
      nI am also trying to figure out how I can submit ansys maxwell file to run on 'Compute Canada' cluster which uses SLURM scheduler. I am completely new to HPC. I appreciate if you help me through learning.nThank You.n n
    • ANSYS_MMadore
      Arrayyou should contact Compute Canada for guidance on usage of their cluster, they would need to install and configure the applications. If you refer to the 2021R1 ANSYS Help there is information regarding SLURM and Maxwell and Electronics applications.nnThank you,nMattn
  • The topic ‘How can I submit an Ansys Electronics Desktop file to run in a cluster that uses Slurm scheduler?’ is closed to new replies.
