March 8, 2020 at 2:47 pm
anshs
SubscriberI am performing a DPM simulation and I want to save the animation file of particle tracks -> velocity magnitude.Â
I was not able to find an option for this in the calculation activities -> select data quantities.
Thanks. -
March 9, 2020 at 6:06 am
Amine Ben Hadj Ali
Ansys EmployeeUnder solution animation you can assign a path. Under calculation activities you can refer to the folder as you provide the command to store starting from local path (./pics/) as an example -
March 9, 2020 at 10:42 am
anshs
SubscriberI have saved the HSF file in a particular directory, but what to do next? I want to save a video file for presentation purposes!Â
March 9, 2020 at 11:27 am
Amine Ben Hadj Ali
Ansys EmployeeUnder Solution Playback you can read the *.cxa file. You do not need to read a case file for that.Refer to the user's manual.
- The topic ‘How can I save the animation of particle tracks in a folder?’ is closed to new replies.
1618
1386
1242
