Ansys Free Student Software
How can I renew ANSYS student version license?
    • Keyur Kanade
      To renew ANSYS student version license without changing the version or performing a new installation, please use following steps.
      - Go to
      https://www.ansys.com/academic/free-student-products
      Then download one of the following three packages available on this page
      Discovery Live Student : STUDENTDISCOVERY_###_WINX64.zip
      ANSYS AIM Student : AIMANSYSACADEMICSTUDENT_###_WINX64
      ANSYS Student : ANSYSACADEMICSTUDENT_###_WINX64.zip
      Note: Any package and any version that is currently available on the page is OK.
      - Unzip the package that you just downloaded, then look for the folder named ‘student’
      - In this ‘student’ folder, you will see WINX64.7z . Extract (‘unzip&rsquo this file
      - Go inside the unzipped WINX64  -> Shared Files -> Licensing -> Here, you will see 'student.lic' file
       -Copy this 'student.lic' file to where ANSYS is currently installed on your machine default location to replace your old ‘student.lic’ file in your installation directory
    • Ananth Narayan
      But for a small text file (may be around KB) it is not fair to download almost 2 to 3 GB. So my request is to download only licenses file only form website.
    • DiegoBarini
      The download links are not working
    • zarko
      not working
    • Rahulkarn009
      does any one have ansys aim 16.2 version and ansys student 18.2 version  the latest versions are not fully supported in my system
    • vganore
    • Sharath
      Can I get that separate student folder, so that I shouldn't download whole file which will be around 6 GB.
      No, it's not packaged separately.
    • langlinator
      Dear Ansys,
      This is a silly solution, please think about this.
      I want to continue using 2019 R2. It is still available to download from Ansys Student page, so I assume is still supported.
      Please have a think about whether that is sensible.
    • langlinator
      So it seems this procedure doesn't work anyway. Why does Ansys still have 2019 R2 available when the license terminates on 31st May 2020?
      I will have to download a more recent version of Ansys, and hope that my project (being used with scripts) still function as expected when controlled from windows command line.
      I'll get that checked, we did make significant changes to licencing at 2020 so it's possible the older approach no longer works, or rather the new licence isn't compatible.
      However, Student is provided to help you learn, and to supplement the University software provision, it's not supposed to replace the University solution.
Viewing 10 reply threads
  • The topic ‘How can I renew ANSYS student version license?’ is closed to new replies.
