August 3, 2020 at 3:00 am
Keyur Kanade
Ansys EmployeeHow can I measure the angle between circumferential holes on a flat disk in SpaceClaim? -
August 3, 2020 at 3:21 am
Karthik Remella
AdministratorGo to the Dimension tool and hover over first hole to highlight its axis. Once highlighted, select the axis and then hold down CTRL to select the axis located at center of the part on which the holes are created. While still holding CTRL, hover over the second hole and select its axis. The dimension should now show the angle between holes. You can later hide the points in the structure tree if you want to. -
August 3, 2020 at 9:59 am
Keyur Kanade
Ansys EmployeeCan I parameterize this? -
August 3, 2020 at 10:06 am
Karthik Remella
AdministratorPlease check the example at https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/spaceclaim/Discovery/user_manual/scripting.html
expand the Script Group and Parameter example located at the bottom of the page. -
August 3, 2020 at 10:32 am
Keyur Kanade
Ansys EmployeeDoes this work on existing geometry? -
August 3, 2020 at 10:54 am
prajput
No you will have to recreate and record the steps for the operations to parameterize.
Viewing 5 reply threads
- The topic ‘How can I measure the angle between circumferential holes on a flat disk in SpaceClaim?’ is closed to new replies.
1306
