March 11, 2019 at 6:34 pm
wh05
SubscriberHi, I imported a ACIS file into ANSYS DesignModeler. But it come out failed and said: "You have exceeded the allowable geometry limits for ANSYS Academic. You cannot Save or Export. "
So what is the maximum limits can I have? Also, is it mean that I can still undergoes structural analysis but cannot save a soft copy.
Or any solutions?Â
March 11, 2019 at 7:52 pm
peteroznewman
SubscriberThe Student license limits for geometry are 300 faces and/or 50 bodies.
Go back to the original CAD system and reduce the number of faces and/or bodies until you meet this limit.
March 13, 2019 at 11:01 am
wh05
SubscriberThanks. How can I reduce the bodies? Do you mean to delete part of my structure? My structure is a 3 layers of steel frame with concrete slab.
March 13, 2019 at 9:48 pm
peteroznewman
SubscriberYes, you have to remove faces until it is < 300 total if you have a Student license.
Does your structure have a plane of symmetry? If so, you can cut the model in half and use a symmetry region to support the structure. That could reduce a lot of faces.
Do all the edges of the steel have a small blend? If so, you can delete all the small blends.
- The topic ‘How can I import a .SAT file?’ is closed to new replies.
6680
1313
