July 9, 2024 at 12:06 am
July 9, 2024 at 12:07 am
Noura Mansour
SubscriberAnd how can i get batch file to insert it in MatlabÂ
July 9, 2024 at 11:49 am
Devendra Badgujar
Forum ModeratorHello Noura,Â
You can refer this Creating Helix Using Ansys Discovery - Ansys Knowledge which demosntrates the use of Pull tool to create helical springs in Ansys Discovery.Â
When you are creating this helix you can use the Script recorder which will record each operation as a scripting step and can save the script as .dscript or .py format.Â
Script Editor is available under File menu and make sure you start the script recorder highligted in the image below:
Let me know if you have any further questions.Â
Regards,Â
Devendra
- The topic ‘How can i draw nonlinear barrel spring using interpolation circle’ is closed to new replies.
Ansys Innovation Space
1313
1142
1075
1013
