July 31, 2020 at 2:00 pm
Karthik Remella
AdministratorHow can I compute the heat conduction in a solid body? What equation or formula should I use?
prajput
Ansys EmployeeYou can compute it using Fourier's law. It states that the rate of heat transfer through conduction is directly proportional to the thermal gradient (dT/dx). Mathematically,
q_x = - k * A * dT / dx (1D conduction)
where,
q_x - rate of heat transfer in x direction
k - thermal conductivity of the material
A - area normal to the direction of heat transfer
dT / dx - thermal gradient
The minus sign is necessary because heat is transferred in the direction of decreasing temperature.
Karthik Remella
AdministratorThanks @pankajhr , So what is the physical meaning of the thermal conductivity in the Fourier's conduction equation?
July 31, 2020 at 2:01 pm
prajput
Ansys EmployeeThermal conductivity is a transport property which indicates the rate at which energy is transferred through conduction. Efficient conductors have a high thermal conductivity. Materials with poor thermal conductivity are referred to as insulators.
Karthik Remella
AdministratorThanks
Viewing 4 reply threads
- The topic ‘How can I compute the heat conduction in a solid body? What equation or formula should I use?’ is closed to new replies.
1310
