구조
구조
How can i change color of my object?
    • 2026227001
      I am experiencing a persistent issue in Ansys Maxwell 2D/3D regarding object display and color settings.
      1. Color Discrepancy After Duplication: Even when I duplicate an object (whether using Copy/Paste or the Duplicate tool), the color of the new object appears different from the original.
      • I have verified that both objects have identical Properties: the same Material, the same Color code, and Transparency is set to 0 for both.
      • Display Wireframe is unchecked for both.
      • Even when I manually select both objects and force them to the same color, they appear visually different in the Modeler window.
      2. Missing 'Modeler Options' Menu: To resolve this, I attempted to disable the "Automatically assign distinct colors" option. However, I cannot find the Modeler Options under Tools > Options. Only General Options and HPC and Analysis Options are visible in the menu.
      3. Request for Assistance:
      • How can I access the Modeler Options to disable automatic color assignment in the latest version 2025?
      • Why do objects with identical property settings (Color, Transparency, Material) display different shades, and how can I force them to look exactly the same?
      I have attached screenshots of my menu and the color discrepancy for your reference.
      Thank you for your help.
    • mhouriha
      Hi, the picture didn't get attached, could you please reshare it?
  • 이 주제에 회신하려면 로그인해야 합니다.
