TAGGED: 3d-simulation, ansys-fluent, chart, fluid-dynamics
September 16, 2020 at 10:14 am
Eng03dp
SubscriberHello everyone,nHere is my question : I would like to calculate the average temperature on a surface at the outlet of my system (it is a quite simple system : a flow of cold air passes through a hot lattice structure and comes out with a temperature difference). I already know how to calculate the temperature at a point (insert point then create a chart with this point as location), but not at a whole surface.nSo is there any solution to this problem ?nThank you very much n -
September 16, 2020 at 10:25 am
September 16, 2020 at 10:28 am
Forum ModeratorPretty much, I'd look at mass weighted if you want the fluid material to account for small regions of higher velocity fluid though. n
- The topic ‘How can I calculate the average temperature of a surface ?’ is closed to new replies.
