December 11, 2021 at 12:33 pm
Patricia
SubscriberHello everyone!
I am a student of Industrial Engineering Master's Degree. I am currently developing my Final Project and it would be very helpful if someone could please help me with one specific doubt.
I need to use ANSYS Composite PrepPost tool to calculate the Failure Index of a Flat Plate. However, I was not able to find this parameter in the program. The most similar factor I have found is Inverse Reserve Factor within the Composite Failure Tool, but it is not what I need.
The definition of the needed index is as follows:
Failure Index = Ply strain/ Limit strain
When the result is greater than 1, failure is predicted in the ply.
Do you know if there is any way to calculate the Failure Index in ANSYS PrepPost, directly or indirectly?
Thank you in advance and Kind Regards
December 14, 2021 at 7:33 amVinayak Vipradas
To calculate Failure Index for composite ply structures you can use the Composite Failure Tool.
For detailed information on Composite Failure Tool, please refer to the following link:
Composite Failure Tool (ansys.com)
Regards Vinayak
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
January 26, 2023 at 9:00 am
Rameez_ul_Haq
SubscriberI tried alot to find some data on how can we actually observe the Failure Index and/or Strength Ratio for, say, Tsai-Wu criteria for a composite material made of several plys. I couldn't find anything useful. Could you kindly elaborate on where exactly to look in the 'Composite Failure Tool' section? Thank you.
Viewing 1 reply thread- The topic ‘How can I calculate Failure Index by using ANSYS Composite PrepPost?’ is closed to new replies.
6625
1312
