February 13, 2024 at 8:48 am
Haseeb Ahmad
SubscriberHello everyone
i am modelling RCC single span bridge in ANSYS workbench and i want to model the supports of bridge using spring constant values of 2.4kN/mm in X direction, 2.4kN/mm in Y direction, 469kN/mm in Z direction (vertical) but if i see elastic support in ANSYS it shows only one value may be vertical in unit like (kN/mm3). how can i apply 3 spring constant value which resemble the bearing pad of bridge ?
February 13, 2024 at 1:48 pm
Erik Kostson
Ansys EmployeeÂ
Hi
Use 3 body-ground springs (in x y z directions), and assign these 3 constants to the 3 springs as needed.
All the best
Erik
February 13, 2024 at 2:00 pm
Haseeb Ahmad
Subscriberhi
Thank you for your response.
i have seen some tuturial video related to assigning of spring in which they also assign some spring length which i dont know in my case.
Looking for response.
February 13, 2024 at 1:55 pm
Haseeb Ahmad
SubscriberÂ
hi
February 13, 2024 at 2:03 pm
Erik Kostson
Ansys EmployeeÂ
Hi
Length is not really doing anything so can be anything larger than 0 – it is only the stiffness (k) of the spring (for static, for dynamic also damping is important (cv)).
Reference:
13.14. COMBIN14 – Spring-Damper (ansys.com)/forum/forums/topic/how-to-access-the-ansys-online-help/#:~:text=Open%20Ansys%20Workbench%20(or%20any,A%20browser%20window%20will%20open
All the best
Erik
February 25, 2024 at 7:11 am
Haseeb Ahmad
SubscriberThank you so much for help.
- The topic ‘How can i apply spring constant in 3 direction’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3862
1414
1221
1118
1015
