April 3, 2018 at 12:16 pm
thabtisalma
SubscriberHi ,  I've been working on a reaserch, however am facing problem with the application of a cyclic loads on ANSYS. I am a beginner in ANSYS I appreciate any helpÂ
thank you .
April 3, 2018 at 3:46 pm
deepmech.maurya
Subscriber -
April 3, 2018 at 4:27 pm
thabtisalma
Subscribercan i change the number of the cyclics ?Â
April 3, 2018 at 6:57 pm
peteroznewman
SubscriberAre you trying to analyze the structure for fatigue failure? Â
Or are you trying to analyze the dynamic response of the structure to a periodic forcing function?
April 3, 2018 at 11:40 pm
thabtisalma
Subscriberi want to analyse the structure for fatigue failure and study the lifetime of wind turbine bladeÂ
April 4, 2018 at 12:07 am
peteroznewman
SubscriberRead this post about the Fatigue Tool that is included in ANSYS.
You want to be able to load the wind turbine blade in the extreme loads. Is the load always between zero and a positive deflection, or does the blade vibrate between positive and negative deflections?
April 4, 2018 at 12:23 am
April 4, 2018 at 11:33 am
peteroznewman
SubscriberSo if you apply the maximum load of 500 from your graph, and the minimum load is zero, that is a Ratio of 0 and you can put that in the Fatigue Tool to estimate life if you have the fatigue properties for the material in Engineering Data.
April 4, 2018 at 12:47 pm
thabtisalma
Subscriberok thank you so muchÂ
May 5, 2020 at 2:10 pm
BHARATK832
Subscriberhow to define the variable (i.e. w)
October 5, 2023 at 3:40 pm
Ravi Shankar
SubscriberSir i working fatigue life analysis for composite material which stress life (S-N) curve are missing what can i do
- The topic ‘How can I apply Cyclic loading in ANSYS?’ is closed to new replies.
6515
